Called party transformation pattern WITH SIP TRUNK
My question pointed to the below discussion
https://supportforums.cisco.com/discussion/11708211/called-party-transformation-pattern
It was play great with CUCM--h323 VG---PRI but not now with CUCM--SIP VG--SIP TRUNK with ISP
Could you pls share your thoughts?
with this scenarion CUCM--h323 VG--- PRI i was done the below
CUCM Config
Route Pattern: 9.00!
- Called Party Transform: Predot
Route List: YourRouteList
- Called Party Transform: Predot / Prefix 91018
H323 GW Config
Keep the dialpeer as is and add the following:
voice service voip
no supplementary-service h225-notify cid-update
Now with this scenarion??
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
1 REPLY
chrysostomos1980Its pretty
chrysostomos1980
Its pretty much the same, if you cant get this to work do as Bill mentioned in the other post, use translation profiles on the dial-peer level to prefix the digits.
HTH.
Please rate useful posts.
142
