Bronze
Caller ID and InterCluster Trunk
HI
4.02(Calif)---ict---4.1.3(Texas)
CM40 calls Texas local number so we save with least cost routing. However, caller ID is retain with internal did versus the full 10 digit number. I want it to pass 10 digit calling number instead of 5 digit did. For example
Calif 408-555-5555 calls long distance texas at 91-214-555-1111. The 214 phone will show caller id of 15555 instead of 408-555-5555. If I change it to go out the Calif local PRI, I will have caller id of 408-555-5555.
TIA
175
