Caller ID and Q931 debug
I am simply trying to let Call Manager (6.1) set the outbound caller ID rather than the Carrier fixing it..
I requested the Carrier stop messing with Caller ID and let through whatever we set.  They claim to have done this.
All external calls are now showing as "blocked" however..
An ISDN Q931 debug on our 2811 gateway is below.   Does the debug indicate we are sending the Calling Party Number to the Carrier correctly ?
Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '0748239231'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0419736842'
Mar  9 10:10:44: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x94C5
Any assistance appreciated.
Matt.
Re: Caller ID and Q931 debug
This is what you're sending:
If the other end receives something else, something in between is changing it.
Many carriers do not accept something that is not within your DID range and modify it.
If the above phone number is valid then reach telco for some live debugging.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Silver
Hello Matt,
By sending the Plan and Type marked as unknown you are forcing the TELCO to look into all their tables (Subscriber, Long Distance, Internationall) so the call will go through as long as it is properly formatted, the TELCO should then display CLID of 0748239231, have you tried changing the Calling Party Plan and Type to CallManager (This will work as long as you are using the 9.@ Route Pattern and your country dial plan)?. I had a few issues where the TELCO blocks CLID if the call is not being tagged.
Hope this helps!
-- espereir
Hall of Fame Super Gold
Does this number belongs to you ? Otherwise, as java indicated, you cannot expect it to show anywhere.
In this case despite a previous denial from the carrier, a fault was found on their end restricing Caller ID..
thanks for your assistance.
Matt
780
