caller id for extension numbers problem
hi
2851 ccme router and pri line.
when i call outside my extension numbers are missing and pri main number is seen as callerID
debug isdn q931 oputput show correct numbers.
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '3335722'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '05332176396'
i mean pri number is 3335700 and did numbers are 57xx. But when i check my cell phone it look 3335700 instead of 3335722
the only thing that i did is to add prefix '5' for incoming calls by using
voice translation-rule 1
rule 1 // /5/
because the customer wanted to use 57xx extensions. and DID calls working without problem
debug isdnb q931 for incoming calls
tr#
Mar 20 12:05:11.675: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0DE5
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0183, '05325414916'
Called Party Number i = 0xC1, '722'
Plan:ISDN, Type:Subscriber(local)
Sending Complete
i added prefix 5 for match extensions 57xx
note
dial-peer voice 1 pots
corlist outgoing external
description calls over pri
translation-profile incoming prefix
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
1 REPLY
Hall of Fame Super Gold
Re: caller id for extension numbers problem
You have to ask your telco how do they want the number to be in order recognize DID, e.g. how many digits, which plan/type. See for example they use 'subscriber' for incoming while you have the default of 'unknown'
Also double check with customer if it is that they really want because often they don't want the extensions to show when calling outside, at least, not for all extensions.
116
