CALLER ID . FXO
I HAVE CUCM 7.1 AND 3845 ROUTER AS H323 GATEWAY. I CAN NOT RECIEVE CALL ID FROM THE PSTN TO THE IP PHONES.
I ALWYA RECIEVE ( FROM UNKNOW NUMBER ).
VOICE-PORT 0/3/0
CONNECTION PLAR OPX 120
CALLED-ID ENABLE
THIS IS THE FXO PORT CONFIGURATION I HAVE.
PLEASE ADVICE.
Everyone's tags (5)
Hall of Fame Super Gold
CALLER ID . FXO
Are you the end use trying to fix things yourself ?
For start. configure an appropriate cptone for better chances.
And, please, use lowercase as everybody else.
CALLER ID . FXO
I am the engineer installed the system i have studied CVOIE & CIPT1. for the cptone i tried different cptones but no change.
Re: CALLER ID . FXO
Check with a regular phone first.
If it is, check ring commands, also sometime adjusting levels is needed.
Re: CALLER ID . FXO
HI,
Sometimes we need to inform the provider to enable caller id (for cisco gateway). i am not sure what they do from their side
But it happened manytimes to me. it worked. Ana. phones will always show the caller id.
392
