Caller ID hex string sends wrong length
Hello.
I've run into an issue with Caller ID only sending 10 digits. I am using a 2811 with a VWIC 4FXS analog and 12.4-24 T4 IOS.
according to  'debug vpm signaling' the tx calling number shows correctly, but the Caller ID hex strig sets the length to 10:
.Feb 24 13:42:34 EST: [0/1/1] set signal state = 0x0 timestamp = 0
.Feb 24 13:42:34 EST: [0/1/1] htsp_set_caller_id_tx calling num=66555650063 display_info= called num=3434
.Feb 24 13:42:34 EST: [0/1/1] Caller ID String 80 19 01 08 30 32 32 34 31 33 34 32 02 0A 36 35 35 35 36 35 30 30 36 33 08 01 4F 5F
.Feb 24 13:42:34 EST: [0/1/1] htsp_set_caller_id_tx_time Caller ID:FSK_DURING_RING
.Feb 24 13:42:34 EST: [0/1/1] htsp_start_caller_id_tx string length=28
.Feb 24 13:42:34 EST: htsp_call_bridged invoked
The call is coming in via IP using H323. Pertinent config:
voice-port 0/1/1
trunk-group C
echo-cancel coverage 24
timeouts interdigit 3
description FXS Line 2
caller-id enable
dial-peer voice 3434 pots
trunkgroup C
description ADMIN LINE 3434
destination-pattern 3434
forward-digits all
no register e164
dial-peer voice 55501 voip
description Incoming Numbers
incoming called-number .
dtmf-relay rtp-nte h245-alphanumeric
codec g729r8 bytes 60
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs5 media
no vad
Any assistance would be appreciated.
1 REPLY
Hall of Fame Super Gold
What the phone displays? What is the actual problem ?
365
