Community Member
Caller ID ICT
Hi all,
I had a issue with the Caller ID display on the IP phones when I configure a Non-Gatekeeper ICT connection between two Callmanager Cluster.
It seems like when I try to call a phone from Cluster "A" to Cluster "B". I got the 4 digit DN from Cluster "B" phone displayed on Cluster "A" phone.
I understand that the caller display is send from Cluster "B" to A. But I will like the orignating dialed number to appear.
Can anyone help.
1 REPLY
Silver
Re: Caller ID ICT
Hello Jeremy,
I believe that you mean that after the call is connected, you get 4 digits, this is normally a configuration on the route pattern where you need to enter the CLID transformation masks on both clusters.
167
