Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
caller id issue
Jul 11 21:02:34.407: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x007D
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Facility i = 0x91A12702026EE902010F301E0201010A0101A116A014A1120A0101120D39313132343431333238303233
        Calling Party Number i = 0x1183, '9101206712000'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '2023'
                Plan:ISDN, Type:Unknown
Jul 11 21:02:34.415: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x807D
Jul 11 21:02:34.415: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x807D
        Facility i = 0x9FAA06800100820100A1080201010201018400
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jul 11 21:02:38.195: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x007D
        Cause i = 0x8090 - Normal call clearing
Jul 11 21:02:38.215: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x807D
Jul 11 21:02:38.279: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x007D
Jul 11 21:02:38.783: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x007E
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98387
                Exclusive, Channel 7
        Facility i = 0x91A11902026FCA02010F30100201010A0103A108A006800435383030
        Calling Party Number i = 0x0083, '7459'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '2112'
        High Layer Compat i = 0x9181
Jul 11 21:02:38.787: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x807E
        Cause i = 0x8081 - Unallocated/unassigned number Calling Party Number i = 0x1183, '9101206712000'
The caller id shown "9101206712000" is incorrect. it should be either "911206712000" or "01206712000". how can i change it?
Kindly help.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
caller id issue
This is what the telco is sending you, you can have them change it, or if you want you can add a translation rule to the GW to strip  or prefix digits.
HTH,
Chris
1 REPLY
caller id issue
HTH,
Chris
133
