Community Member
Caller-ID Name not show at Telco side?, but the caller id number working
i have PRI's to the telco with CME 4.2 and i sending the CallerID to telco switch. The telco do not see my caller id name, but see my caller id number!
I have tried to configure "isdn supp-service name calling" but no success
Any ideas?
Brian
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Caller-ID Name not show at Telco side?, but the caller id nu
You are sending a name:
Display i = 'Arc Operator 1'
But as mentioned before, it is rightly ignored by telco.
Probably even if you send a name to PSTN, it will not make any difference. The reason is because you could impersonate a third party, or use an offensive name, so telco just ignores names.
However, the command to do so, is: "isdn outgoing ie display".
Community Member
thank you for your help!
but i alrealdy did that command:
This is my config
interface Serial0/0/0:23
isdn switch-type primary-ni
isdn incoming-voice voice
isdn outgoing display-ie
That makes the name to go out as display IE:
Dec 17 17:57:45.574 CET: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x42
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'P. Bevilacqua'
Calling Party Number i = 0x0080, '28'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '187'
Sending Complete
Then as mentioned before, when connecting to PSTN, it won't make any difference if you send a name or not.
Community Member
yes let me see what name it is send it
you a debug isdn q931 to have that result ?
Yes. Alway have debug isdn q931 when doing isdn things.
Community Member
ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x1B16
Bearer Capability i = 0x8090A2
Standard = CCITT
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A116020173020100800E417263204F70657261746F722031
Protocol Profile = Networking Extensions
0xA116020173020100800E417263204F70657261746F722031
Component = Invoke component
Invoke Id = 115
Operation = CallingName
Name Presentation Allowed Extended
Name = Arc Operator 1
Calling Party Number i = 0x2180, '4188711622'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '4182645859'
Community Member
i SEE THE NAME Name = Arc Operator 1 ,
BUT IT IS NOT SHOWING UP AT THE PROVIDER
THE TELCO IS BLOCKING MY CALLER ID NAME?
Community Member
OK, I UNDERSTAND, IF TELCO IGNORED MY CALLER id
HOW COMES I CANNOT SEE IT ON REMOTE PHONE UNDER A PSTN NETWORK?
Hi, this is exactly because telco ignores your caller name, so you do not see on a remote phone.
Imagine if anyone was allowed to send profanities as a name, would you like that ?
Telco network is not a chatline where you can choose name as you better like :)
Community Member
BUT I CALLED TELCO AND THEY TOLD ME THAT HE IS NOT BLOCKING ANYTHING .. ..:( I WILL CALL THEM TO TROUBLESHOOT THAT ISSUE WITH THEM .. Thanks
by the you are ccie the exam was difficult?
Hi, telco will always reply "we do not block anything" to avoid discussions -- even if they don't even understand the question.
And yes, the CCIE exam is very difficult.
Thanks for the nice rating and good luck!
236
