Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Caller ID not desplaid on UC560!
I am having trouble for caller id to be desplaid on ip phone for incoming calls in UC560.
Do you have any idea what should I modify in order for this to work, other than 'caller-id enable' under voice port.
thanks,
Brj
1 REPLY
Hi.
First activate a debug vpm all to verify if carrier is sending you the caller id and if you can post the output here.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
134
