Caller id not shown for outgoing calls in CME
I have a CME in which 20 ip phones connected, my issue is that calles are not showing the Caller Id of the originating phone,It is only showing my pilot number for all the calls
Call flow
IP Phone---CME---Mobile Number
I am not getting the originating ephone number instead getting the pilot nummber.
Re: Caller id not shown for outgoing calls in CME
What do you mean you are seeing the "pilot number" ?
IF you telnet to the router, enable "debug ISDN q931" and terminal monitor and make an outgoing call, you will see the call detail.
Check the "Calling number" detail on the call in question. If this shows the number you want to be shown then it could be the E1 provider replacing the calling number digits on your behalf.
If it doesnt show the number you want, it could be being modified by a translation outgoing. Check your dial peer for any commands relating to translations and tie these up with the translations at the top of the config.
These can be a little confusing if your not used to them so if you post the patterns themselves we can help decode them for you.
Here is the output of isdn q931 debug:
Also attaching the config for your sugession.
Router#csim start 85148712
csim: called number = 85148712, loop count = 1 ping count = 0
Nov 10 19:12:53.667: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=85148712, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=85148712
Nov 10 19:12:53.667: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=85148712, Expanded String=85148712, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Nov 10 19:12:53.671: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=5 Is Matched
Nov 10 19:12:53.671: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
Nov 10 19:12:53.671: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=5
Nov 10 19:12:53.675: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x0, Called num 5148712
Nov 10 19:12:53.675: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x027B
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838A
Exclusive, Channel 10
Called Party Number i = 0x80, '5148712'
Plan:Unknown, Type:Unknown
Nov 10 19:12:53.719: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x8
27B
Nov 10 19:12:53.739: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8
27B
Progress Ind i = 0x8288 - In-band info or appropriate now available
ccappmib: insertion error. duplicate name CSIM
Nov 10 19:12:55.819: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=83176030, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=83176030
Nov 10 19:12:55.819: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=83176030, Expanded String=83176030, Calling Number=
Nov 10 19:12:55.819: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Nov 10 19:12:55.819: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=5
Nov 10 19:12:55.819: %SYS-3-MGDTIMER: Running timer, init, timer = 456196B0. -Pr
ocess= "Virtual Exec", ipl= 0, pid= 92, -Traceback= 0x415507BC 0x42860FC8 0x426
33E04 0x4159CB20 0x415C0894 0x42857378 0x4285735C
Nov 10 19:12:55.827: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x0, Called num 3176030
Nov 10 19:12:55.827: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x027C
Standard = CCITT
Channel ID i = 0xA98389
Exclusive, Channel 9
Called Party Number i = 0x80, '3176030'
515
