caller ID not working internally
We have hit a situation where a set of very important users  ( around - 5 ) are not having there caller ID displayed on internal calls.   ASCII box is filled up correctly and the other users have it running fine ?     What can be the things , i should check to troubl even further, is it something we have access to or is it a Telco thing like caller id for outside calls ?
Whatever level you reach getting better never stops -- Sachin Tendulkar
Everyone's tags (3)
VIP Super Bronze
Is this cucm or CUCME? What model of phones?
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
This is cucm version : 6.1.x
phone models : 7962
Hall of Fame Super Red
Hi Abhishek,
The settings that effect the Name Display are on the DN configuration page
look for both places to change;
Under Directory number information (top of page)
Under Line x (bottom of page)
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Hi Rob,
Yes , that part is something that has been double- checked and is surely never missed.
Is there something else , which we can look into , to see if thats is missing ?
Re: caller ID not working internally
Hi Abhishek,
Are these shared lines?? If so, have you checked all 4 settings on
all the shared line appearances? Having it set on one phone of a
shared line config but not another will impact the outcome
For calls that you make to the DN, these configs are used for CLID;
When they call you, these configs are used for CLID;
Cheers!
Rob
Have you checked there's not something in the middle like a TP or transformation rule (can't recall if your version has them) that is stripping the info??
Are you 100% sure the call does not go by any other element in CUCM and is a direct call??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks.. Rob ! Let me check
901
