Community Member
Caller ID not working on H323 Gateway
I have a CCM Version 4.1.3 set-up to cater for 200 phones, I have a VG gateway in one of the sites that uses an FXO card for local calls, this VG is set-up as an H323 gateway, however calls coming throguh the PSTN line onto the FXO card and then onto an IP phone are not displaying Caller ID.
Just wondering if anyone has seen this before, I know that on an MGCP gateway the FXO cards don't support Caller-ID but we have it set-up as H323.
Paul
Bronze
Re: Caller ID not working on H323 Gateway
Funny, this is a question straight from one of the CCVP tests, although I won't say which one.
Try "caller-id enable" in global mode and "station-id name" on the voice-port.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a00800a9a49.shtml
Bronze
What model FXO card do you have? I ran into that problem with the 2 port FXO card. There's 3 versions and 1 doesn't support caller ID even with h.323...and that's the one I have!
VIC-2FXO No Caller ID Support
VIC-2FXO-M1 Caller ID Support
VIC2-2FXO Caller ID Support
Bronze
I have the VIC-2FXO as well but never hooked it up to an actual phone line (use was strictly lab to try out commands).
You are correct, these cards to not support Caller ID.
Community Member
Add the following under the voice-portx/x/x
caller-id enable
caller-id alerting line-reversal
I have this working on a 2901 H.323 gateway with an VIC2-FXO.
449
