Caller-id not working on IOS voice-gateway
Hi all,
I have a 2811 running IOS 12.4(24)T and set up as H.323 gateway for a UCM 7.1 cluster. This router has 2x VIC2-4FXO and 1x VWIC2-2MFT-T1/E1.
Both inbound and outbound calls are working fine on all FXO ports and also on the E1 line but I can't get caller-id working on any of them. I have tested the analog lines that are connected to router's FXO ports with an analog telephone and it does show the correct caller-id, but when this line is connected to the router's FXO, the IP Phones will show "Unknown Number". The same happens with the E1 line... with an old Analog PBX I do get the caller-ids but with the E1 line connected to the H.323 gateway, it won't work.
We have read many Cisco docs about this issue but didn't help at all. I guess we're missing something related to this gateway configs.
Current router config and ccapi debugs are attached.
Any Ideas?
Guilherme
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Caller-id not working on IOS voice-gateway
For analog, I understand that Brazil has a different standard (BINA) and it is not clear if Cisco support that or not (I think it does not)
For E1 R2, you need "ani" option in ds0-group, after that take "debug vpm signal", do not take any other debug.
Bevilacqua,
Do you mean "ani-digits" ?
I'm going to try that as soon as I can. The E1 line is currently in use by an Analog PBX so unfortunately I can't test that right now.
About the FXO, it's not a huge problem if clid doesn't work over those lines.
Thanks !
Guilherme
Guilherme,
Send me a "debug isdn q931"
Many Thanks,
Nico
debug isdn q931 does not apply, because there is no ISDN in this case.
Add the "ani" in config:
change from:
controller E1 0/3/0
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled
change to:
controller E1 0/3/0
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
Many Thanks,
Nico
I just tested it with the E1 line and CLI is working fine, thank you guys!
I just need to check about the FXO issue now but it's not a huge deal yet.
Guilherme
Hi Guilherme,
Glad to be of assistance!!
Can you please give me marks so I can count up some NetPro points?
Many Thanks,
Nico
Guilherme,
did you ever sort out your Caller-ID problem on the FXO ports?
I have exact same problem, PSTN line works with Caller-ID when connected to analog phone but when connected to router with FXO port I just get Unknown Number
Please open new thread for new problems, include port configuration, output of "debug vpm signal" when receiving a call.
671
