IP Telephony and Phones
Labels
When I use Audacity to record greetings for Unity Call Handlers, I can export them as WAV 16-bit. I can upload the file and it plays successfully. If I do the same for a CCX prompt, it does not play - just noise is heard. I've ended up downloading an...
SteveK066 by Level 1
  • 639 Views
  • 7 replies
Dear All,I have both Cisco & Non-Cisco IP Phones which are reigistered in my voice gateway. Now i have got ISDN with DID's. How can i allocate some DN with DID number in order to call in both ways ( each extension 5000 calls outside, its DID should g...
techguy by Level 4
  • 5356 Views
  • 14 replies
Hi All, I'm trying to establish a SIP trunk to an ITSP using TLS and SRTP. We think we have done all the trust point stuff and TLS seems to be OK. However, I'll a little lost on the SRTP. Looking at several guides looks like a few different methods. ...
Resolved! Alternating ring
Our old work phones would take turns around the room. I don't think it was called hunt group, but once logged in to your group/extension...it would go around the room on whose turn it was to answer. Is there a way to do that? Thanks
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work. I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto an...
matee by Level 1
  • 112 Views
  • 2 replies
