Caller-ID on digital E&M T1
First time setting up an SRST router. I have everything working but I am not getting any caller-ID. Phone reads UNKNOWN and the status on the router shows:
May 24 20:04:30.926: //-1/80ED7877826D/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8136, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8136
May 24 20:04:30.930: //-1/80ED7877826D/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
May 24 20:04:30.930: //-1/80ED7877826D/DPM/dpMatchSafModulePlugin:
   dialstring=8136, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
May 24 20:04:30.930: //-1/80ED7877826D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=3
     2: Dial-peer Tag=2
Sh controller T1:
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (460 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:0         01  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         02  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         03  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         04  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         05  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         06  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         07  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         08  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         09  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         10  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         11  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         12  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         13  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         14  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         15  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         16  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         17  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         18  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         19  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         20  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         21  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         22  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         23  e&m-wnk     up    dorm idle     idle     y
0/0/0:0         24  e&m-wnk     up    dorm idle     idle     y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/1          2      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/2          2      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/3          2      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/4          2      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/5          2      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
50/0/6          2      efxs     up    up   on-hook  idle     y
50/0/7          1      efxs     up    up   on-hook  idle     y
50/0/7          2      efxs     up    up   on-hook  idle     y
50/0/8          1      efxs     up    up   on-hook  idle     y
50/0/8          2      efxs     up    up   on-hook  idle     y
50/0/9          1      efxs     up    up   on-hook  idle     y
50/0/9          2      efxs     up    up   on-hook  idle     y
50/0/10         1      efxs     up    up   on-hook  idle     y
50/0/10         2      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Any help on this?
THANKS!
Everyone's tags (4)
422
