01-25-2007 06:04 AM - edited 03-14-2019 07:44 PM
I'm on CCM 4.1(2)SR1, and currently, when a user forwards calls to another phone, the caller-id shows the number that the call was forwarded from rather than the actual calling-number.
Is there a way around this?
Thanks.
01-25-2007 06:39 AM
What are your Forwarded Call Information Display settings on the DNs?
01-25-2007 02:52 PM
Hi Jeff,
The settings that Mike (good work Mike!) is referring to are talked about in this good Q&A doc;
You can change the forwarding information on a line by line basis. Have a look;
Forwarding Enhancements
Q. Is there anyway that I can on an incoming call show who redirected the call to me?
A. Yes, in Cisco CallManager 4.0, the system administrator can configure the information that is displayed when a phone is forwarded. The following information is available for display: Original Dialed Number (ODN) (Enable); Redirected Dialed Number (RDN) (Disable); Calling Line ID (CLID) (Enable); Calling Name ID (CNID) (Disable). Each of the listed parameters is configurable on a line appearance basis.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00801f8e18.shtml
Hope this helps!
Rob
