Caller ID pass through using partial rerouting
Hi Folks,
I am having issues with a ISDN e1 provider regarding caller ID on call forwarded calls. Caller ID on a call forward call only shows as the default CLI for the ISDN line...
However, users in the office assure me that it is possible previously to allow the caller ID pass through on call forwarded calls. The telco has said I need to enable partial rerouting???
I am using MGCP and a e1 ISDN line. Does anyone have any idea what this means or how I can configure it?
Google has led me to the below link, but this doesn't seem very possible. Any input appreciated...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t11/ivrapp/ivr_tbct.htm#wp1014035
Hall of Fame Super Gold
In whihc country are you located ?
Can you ask your telco what exacly it 'partial re-routing' ?
Re:Caller ID pass through using partial rerouting
I will find out in more detail from the Telco tomorrow but I just wanted to confirm if there was other ways to get caller I'd pass through working...
At other sites I would just need to set the ISDN type and call type and tick the 'use External call transform mask' on route pattern to get this to work but again that is with the screening table turned off on PRI...
Sent from Cisco Technical Support Android App
796
