Community Member
Caller ID presentaion on call manager with NI2 signalling
Dear All,
I have callmanager 4.2 integrated with harris pbx using NI2 signalling , when analog phone from pbx call ip phone caller id presented good and appear on the ip phone but when i call from ip phone to PBX the caller id oh ip phone not appeared just appear the extension number , although I allowed "Calling Line ID Presentation*" on the gateway configuration.
your fast replay is highly appreciated.
Hall of Fame Super Gold
Re: Caller ID presentaion on call manager with NI2 signalling
Are you using h.323 or mgcp ?
And, you need to take "debug isdn q931" for the call that gives you problem.
Community Member
I am using mgcp protocol
Post the debug q931 output.
Do not enable any additional debug, include the rouble call only, do not use attachments.
Community Member
kindly find attached debug Q931
*Mar 14 14:43:52.754: ISDN Se3/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '6578'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4994'
*Mar 14 14:43:52.934: ISDN Se3/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8001
*Mar 14 14:43:52.958: ISDN Se3/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x8001
*Mar 14 14:43:56.910: ISDN Se3/1:15 Q931: RX <- CONNECT pd = 8 callref = 0x8001
Connected Address i = 0xA1, '7593'
*Mar 14 14:43:56.914: ISDN Se3/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0001
Gateway#
Sorry, I'm not familiar with mgcp to tell you why router does not send calling name.
Hopefully somebody elese will.
Community Member
hi guys,
if anybody can help me?
Under your router serial interface issue:
isdn outgoing display-ie
Which is off by default.
Edit: to get the name presented you need to select Calling Name Presentation: Allowed. This is in Route Pattern configuration.
Calling Line ID Presentation is for ANI representation, not for names.
And ofcourse, the other PBX must support it.
Are you doing QSIG?
Community Member
First I'd like to thank you for your fast replay , but I configured this command under the serial interface also I allowed the Calling Name Presentation on the route pattern configuration and the problem still not solved.
Nothing that you configure on the interface will help, because you're using MGCP.
Community Member
Thanks for all your replies and I solved the problem using ETSI signalling , configuring the PBX as user side and the callmanager as network side , also configured this command under serial interface "isdn protocol-emulate network"
443
