02-25-2009 01:32 PM - edited 03-15-2019 04:28 PM
Hi all
Which configuration should I make so that each caller is presented using his First and Last name and not the DN,
Extension Mobility is used !!
thanks in advance
02-25-2009 02:18 PM
When you fill the Display (Internal Caller ID) and the Alerting Name
in your line configuration [in case of a device or a device profile] , you will have a caller ID presenation instead of your DN.
Then if you need to control if you need to display the DN or not,it is by enabling the check box in your line configuration also.
02-25-2009 10:53 PM
No way to use the First and Last name of the Extension Mobility user, so we can avoid to fill 2 other fields ?
best regards,
02-26-2009 02:52 AM
Hi tka,
Yes, the extension mobility use the device profile that you will fill the 2 fields i have asked you to fill in my last mail
you must fill these fields in the device profile with the same first and last names you did in the user configuration to be the same as you want
I wish this be helpful
