10-16-2010 04:04 AM - edited 03-16-2019 01:22 AM
I have two cisco 2800 routers, one of the fxo ports on the first router is connected to the PBX, on the other side I have similar router with fxs interface connected to analog telephone, when calling the fxs port the caller id is not displayed on the analog telephone, I run the command "show history voice on the router with the fxs interface and I can see the caller id is displayed correctly and identified, I changed the analog phone and still the same.
10-16-2010 07:48 AM
If you do not send relevant config for both routers, nothing can be suggested.
10-17-2010 12:45 AM
Yes, also please explain what the exact topology is. What is the call control signaling used ? Is it H323 to MGCP ?
Something like this will be helpful :
Telco ---- FXO ---Router ---- h323 or mgcp ?? ---- CUCM or router ----- FXS --- analog phone
So what we will need :
1. configuration from the router
2. exact call flow
3. version on the routers
Thanks and Best Regards,
Pashmeen Mistry
10-19-2010 06:55 AM
sorry for being late my configuration as you said:
Telco ---- FXO ---router---- h323and sip?? ---- router ----- FXS --- analog phone
here is the configuration of the two gateways:
router2#sh version
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Aug-08 17:09 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
router2 uptime is 23 hours, 48 minutes
System returned to ROM by reload at 13:51:53 UTC Mon Oct 18 2010
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.50) with 223232K/38912K bytes of memory.
Processor board ID FCZ1308707T
2 FastEthernet interfaces
1 Serial(sync/async) interface
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router with fxo interfaces
router2#sh run
Building configuration...
Current configuration : 2268 bytes
version 12.4
hostname router2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
hidekeys
interface Loopback0
no ip address
interface FastEthernet0/0
ip address 192.168.6.107 255.255.255.0
duplex full
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
no fair-queue
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.6.1
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
no battery-reversal
soft-offhook
signal groundStart
connection plar 10835
station-id number 10835
caller-id enable
voice-port 0/0/1
no battery-reversal
signal groundStart
compand-type a-law
cptone LB
timeouts call-disconnect 5
timeouts wait-release 1
connection plar 01256879
impedance complex1
caller-id enable
voice-port 0/1/0
no battery-reversal
cptone FR
connection plar 10833
voice-port 0/1/1
no battery-reversal
connection plar 10832
dial-peer cor custom
name 83pstn
name 01pstn
name 07pstn
name 09pstn
name 05pstn
dial-peer cor list allow
dial-peer cor list norestrict
member 83pstn
member 01pstn
member 07pstn
member 09pstn
member 05pstn
dial-peer voice 10 pots
destination-pattern 10...
port 0/0/0
dial-peer voice 100 pots
port 0/1/0
dial-peer voice 1000 pots
port 0/1/1
dial-peer voice 1 pots
destination-pattern ........
port 0/0/1
dial-peer voice 2 voip
destination-pattern 01256879
session target ipv4:10.3.3.101
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 3 voip
session protocol sipv2
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
FXS:
boot-start-marker
boot system flash:c2800nm-spservicesk9-mz.124-24.T1.bin
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name yourdomain.com
no ipv6 cef
voice service voip
fax protocol cisco
sip
voice-card 0
log config
hidekeys
class-map match-all matchany
match protocol rtp audio
class-map match-all rtp
policy-map rtp
class matchany
police cir 8000
conform-action drop
class rtp
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 10.3.3.101 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
no cdp enable
no mop enabled
interface Serial0/0/0
no ip address
encapsulation ppp
shutdown
no fair-queue
clock rate 2000000
no cdp enable
ppp multilink group 44
no ip classless
ip route 0.0.0.0 0.0.0.0 10.3.3.1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal
snmp-server enable traps adslline
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps license
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps pw vc
snmp-server enable traps ccme
snmp-server enable traps srst
snmp-server enable traps mpls vpn
snmp-server enable traps voice
snmp-server enable traps dnis
control-plane
voice-port 0/2/0
description 10832
caller-id enable
voice-port 0/2/1
connection plar 10579
description 10835
caller-id enable
voice-port 0/3/0
ring cadence pattern02
cptone LB
description 01256879
station-id number 01256879
caller-id enable
caller-id format e911
voice-port 0/3/1
ring cadence pattern01
cptone FR
description 10833
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
name 01calls
name 83cellular
dial-peer cor list outpstn
member 01calls
dial-peer cor list 83out
member 83cellular
dial-peer voice 10832 pots
destination-pattern 10832
port 0/2/0
dial-peer voice 10835 pots
destination-pattern 10835
port 0/2/1
dial-peer voice 10833 pots
destination-pattern 10833
port 0/3/1
dial-peer voice 108 voip
session target ipv4:192.168.6.107
dial-peer voice 103 voip
destination-pattern .T
port 0/3/1
forward-digits all
sip-ua
retry invite 2
retry response 2
retry bye 2
retry cancel 2
line con 0
login local
line aux 0
line vty 0
privilege level 15
login
transport input telnet
line vty 1 4
privilege level 15
no login
line vty 5 988
no login
end
