Caller ID shows number,name only after phone is answered. Any way to show name prior to answering? V7.1.3 Call Manager
Hi, I've recently taken over support of a 7.1.3 Call Manager. I have my PRIs terminating into a 2800 series router. When a call comes into desk phones the caller-id number is displayed correctly but the caller-id name does not display until after the call is answered. So my phone rings and I see 5558675309 and when pick it up it then shows "Jenny" as the name. I'd like to configure our system to show the name prior to answering the call so we can know who is actually calling. Any ideas or suggestions or additional info needed?
- Eric
Hall of Fame Super Gold
Re: Caller ID shows number,name only after phone is answered. An
Are you sure the name does not appears even if you wait, say, 15 seconds before answering ?
Hi, No it doesn't matter when the call is picked up.  As soon as the phone rings I see the # and I if I pick it up a half second later the name displays. The same is true if I wait after several rings, just before it goes to voice mail.
- Eric
What does a 'debug isdn q931' look like for your inbound call?
CUCM should be sending the calling name to the IP phone when it is received by the gateway.  If we aren't getting the name before Connect then there's not much we can do.
Bronze
Questions for you -
Are these PRI's coming in from the network?  What carrier?  Are you using H.323 from the voice gateway or another protocol?
Hi Les, the PRIs are coming in from Time Warner Telecom.  Gateway config below as I am not sure the answer to your protocol question.
- Eric
version 12.4
service password-encryption
boot-start-marker
boot-end-marker
card type t1 0 2
logging message-counter syslog
logging buffered 1000000
no logging console
no aaa new-model
clock timezone EST -5
clock summer-time DST recurring 2 Sun Mar 0:01 1 Sun Nov 0:01
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice call carrier capacity active
voice service pots
supplementary-service qsig call-forward
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
  h225 timeout ntf 1000
sip
  registrar server expires max 600 min 60
voice statistics type csr
voice statistics time-range since-reset
voice translation-rule 1000
rule 1 /^9001\(..........\)/ /9\1/
voice translation-profile outgoing
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
archive
log config
  hidekeys
controller T1 0/0/0
pri-group timeslots 1-24 service mgcp
controller T1 0/0/1
controller T1 0/2/0
cablelength long 0db
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
bandwidth inherit
ip address 172.x.x.x 255.255.252.0
ip flow ingress
duplex auto
speed auto
h323-gateway voip bind srcaddr 172.x.x.x
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn map address ^9011T plan unknown type unknown
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/2/0:23
no ip address
encapsulation hdlc
no cdp enable
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
control-plane
voice-port 0/0/0:23
bearer-cap Speech
voice-port 0/2/0:23
voice-port 0/0/1:23
ccm-manager mgcp
ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.x.x.x
ccm-manager config
mgcp
mgcp call-agent 172.x.x.x 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.x.x.x identifier 1 priority 1 version 6.0
sccp
sccp ccm group 99
description tvg1 conf
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 111 register tvgltxcode
sccp ccm group 1
associate profile 50 register sip123456789101
dspfarm profile 111 transcode
description transcode profile 111
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
dspfarm profile 3 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
shutdown
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dial-peer voice 20000 pots
service mgcpapp
port 0/0/0:23
dial-peer voice 20 voip
destination-pattern 2...
session target ipv4:172.x.x.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 1111 pots
destination-pattern [2,3]...
direct-inward-dial
port 0/0/0:23
forward-digits 4
dial-peer voice 1112 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 6500 pots
destination-pattern 6500
clid restrict
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 2000 pots
destination-pattern 900$
prefix 0
dial-peer voice 8800 pots
destination-pattern 88..
direct-inward-dial
forward-digits all
dial-peer voice 112 pots
dial-peer voice 9900 pots
destination-pattern 00
direct-inward-dial
forward-digits all
dial-peer voice 10 voip
shutdown
destination-pattern 4..
codec g711ulaw
no vad
dial-peer voice 10002 voip
session protocol sipv2
codec g711ulaw
dial-peer voice 4 pots
shutdown
dial-peer voice 1116 voip
destination-pattern 9001..........
dial-peer voice 1113 pots
destination-pattern 90115T
direct-inward-dial
port 0/0/0:23
forward-digits 13
dial-peer voice 1114 pots
destination-pattern 901120T
direct-inward-dial
port 0/0/0:23
forward-digits all
dial-peer voice 1117 pots
port 0/0/0:23
dial-peer voice 1115 pots
destination-pattern 901127T
direct-inward-dial
port 0/0/0:23
forward-digits 12
prefix 011
dial-peer voice 1118 pots
description US to China Calling
destination-pattern 901186T
direct-inward-dial
port 0/0/0:23
forward-digits all
prefix 011
gateway
timer receive-rtp 600
sip-ua
timers buffer-invite 500
line con 0
login
line aux 0
line vty 0 4
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
no login
scheduler allocate 20000 1000
end
On running the debug I see the Calling Party number only for any call coming in. I ran debug for 15 min to make sure I captured enough call volume to verify.  At no point does the name show up in the debug, regardless if the call is answered or not.  So at what point is the name sent?
- Eric
Oct  5 16:06:46.017: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x0378
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
        Calling Party Number i = 0x2183, '9xxxxx1206'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '2833'
                Plan:Unknown, Type:Unknown
Oct  5 16:06:46.041: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
378
Your debug only shows the first part of the call so I can't tell where the name was delivered.  There is no DisplayIE and from what I can tell of the FacilityIE there's no calling party name in it either.
Hi Phillip, Here is a larger snippet of the debug log.  Are you refering to the line "Facility i = etcetcetcetc" that should contain the calling party? I am confused why the name does work so it must be transmitted at some point from the carrier, but we do not see it.
- Eric
Oct  5 18:11:05.157: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x03E4
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '5552148522'
        Called Party Number i = 0x80, '2999'
Oct  5 18:11:05.181: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
3E4
Oct  5 18:11:05.193: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x83
E4
        Facility i = 0x9FAA06800100820100A10C020101020101800439303530
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Oct  5 18:11:05.377: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x83E
        Facility i = 0x9FAA06800100820100A1080201020201028400
        Connected Number i = 0x0081, '9077'
Oct  5 18:11:05.401: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x03E4
Oct  5 18:11:05.681: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E4
        Facility i = 0x9F8B0100A115020101020100800D424F55434845522C454D494C59
Oct  5 18:11:11.545: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DC
Oct  5 18:11:11.549: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DC
        Cause i = 0x829E - Response to STATUS ENQUIRY or number unassigned
        Call State i = 0x0A
Oct  5 18:11:12.753: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DA
Oct  5 18:11:12.757: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DA
        Call State i = 0x0A
Oct  5 18:11:12.805: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DB
Oct  5 18:11:12.805: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DB
        Call State i = 0x0A
Oct  5 18:11:13.753: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DD
Oct  5 18:11:13.753: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DD
        Call State i = 0x0A
Oct  5 18:11:22.557: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
8249
        Cause i = 0x8490 - Normal call clearing
Oct  5 18:11:22.637: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x024
9
Oct  5 18:11:22.665: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8249
Oct  5 18:11:30.501: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x03E5
                Standard = CCITT
        Channel ID i = 0xA98392
                Exclusive, Channel 18
        Calling Party Number i = 0x2183, '5554012100'
        Called Party Number i = 0x80, '2800'
Oct  5 18:11:30.533: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
3E5
Oct  5 18:11:30.533: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
        Facility i = 0x9FAA068001008201008B0100A114020101020114300C0A01010A01028
00436353031
Oct  5 18:11:30.541: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x83
E5
        Facility i = 0x9FAA06800100820100A1080201010201018400
Oct  5 18:11:30.733: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x83E
        Facility i = 0x9FAA068001008201008B0100A10B02010102011630030101FF
        Connected Number i = 0x80, '6501'
Oct  5 18:11:30.761: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x03E5
Oct  5 18:11:30.845: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
93E5
        Cause i = 0x8090 - Normal call clearing
Oct  5 18:11:30.857: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
83DF
Oct  5 18:11:30.885: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x13E
Oct  5 18:11:30.897: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x03D
F
Oct  5 18:11:30.921: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x93E5
Oct  5 18:11:30.925: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E5
        Facility i = 0x9F8B0100A113020101020100800B50454F504C45434C49434B
Oct  5 18:11:30.941: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x83DF
Oct  5 18:11:30.953: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x00BE
        Sending Complete
                Standard = CCITT
        Facility i = 0x9FAA06800100820100A116020100020100800E537573616E20526F626
96E736F6E
        Calling Party Number i = 0x2181, '5556450907'
        Called Party Number i = 0x80, '9966890'
Oct  5 18:11:31.033: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x80
BE
        Facility i = 0x9F8B0100A406020100810101
Oct  5 18:11:31.449: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8
0BE
Oct  5 18:11:33.997: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x80
BE
        Progress Ind i = 0x8488 - In-band info or appropriate now available
Oct  5 18:11:38.985: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x80B
E
Oct  5 18:11:38.989: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x00BE
Oct  5 18:11:43.705: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x03E6
                Standard = CCITT
        Calling Party Number i = 0x2183, '5555358954'
        Called Party Number i = 0x80, '2957'
Oct  5 18:11:43.733: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
3E6
Oct  5 18:11:43.733: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x83
E6
        Facility i = 0x9FAA06800100820100A114020101020101800C4E616C696E69204D6F7
46861
Oct  5 18:11:44.249: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E6
        Facility i = 0x9F8B0100A1080201010201008400
Oct  5 18:11:46.349: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
Oct  5 18:11:48.305: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x83E
6
        Facility i = 0x9FAA06800100820100A114020102020102800C4E616C696E69204D6F7
46861
        Connected Number i = 0x0081, '2957'
Oct  5 18:11:48.341: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x03E6
Oct  5 18:12:09.038: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
03DD
Oct  5 18:12:09.074: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x83D
D
Oct  5 18:12:09.098: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x03DD
Oct  5 18:12:12.718: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
        Facility i = 0x9FAA068001008201008B0100A114020101020114300C0A01030A01028
00436353031
Oct  5 18:12:12.770: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
Oct  5 18:12:22.358: %SYS-5-CONFIG_I: Configured from console by eroberson on vt
y0 (172.23.5.49)
Oct  5 18:12:37.030: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DE
Oct  5 18:12:37.030: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DE
        Call State i = 0x0A
Oct  5 18:12:37.046: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93E0
Oct  5 18:12:37.046: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13E0
        Call State i = 0x0A
Oct  5 18:12:37.630: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
03DA
Oct  5 18:12:37.634: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x83DA
        Call State i = 0x0A
Oct  5 18:12:38.686: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E4
00436353031
Oct  5 18:12:38.758: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E4
Oct  5 18:12:38.870: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
938D
Oct  5 18:12:38.874: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x138D
        Call State i = 0x0A
Oct  5 18:12:39.470: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93DF
Oct  5 18:12:39.474: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13DF
        Call State i = 0x0A
Oct  5 18:12:40.054: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93E1
Oct  5 18:12:40.058: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13E1
        Call State i = 0x0A
Oct  5 18:12:48.810: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
Oct  5 18:12:53.107: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x13E6
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Facility i = 0x9FAA06800100820100A117020100020100800F414D414E44412057415
445524D414E
        Calling Party Number i = 0x2181, '5556452836'
        Called Party Number i = 0x80, '15552503900'
Oct  5 18:12:53.183: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x93
E6
Oct  5 18:12:53.563: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
3E6
Oct  5 18:12:53.795: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x03E7
                Standard = CCITT
        Channel ID i = 0xA98395
                Exclusive, Channel 21
        Calling Party Number i = 0x2182, '5559931111'
        Called Party Number i = 0x80, '2899'
Oct  5 18:12:53.823: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
3E7
Oct  5 18:12:53.839: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x83
E7
Oct  5 18:12:53.871: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x83E
7
        Connected Number i = 0x0081, '9076'
Oct  5 18:12:53.899: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x03E7
Oct  5 18:12:54.403: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x93
E6
Oct  5 18:12:54.571: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E7
        Facility i = 0x9F8B0100A117020101020100800F5041524B204E49434F4C4C4554204
Oct  5 18:12:56.999: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x93E
6
        Progress Ind i = 0x8482 - Destination address is non-ISDN
Oct  5 18:12:57.003: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x13E6
Oct  5 18:13:10.819: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E7
        Facility i = 0x9FAA06800100820100A1270202111D02010C301E0A0100A0098004303
932370A0101800B42696C6C204361726D616E0A0100
Oct  5 18:13:10.839: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E7
        Facility i = 0x9F8B0100A4070202111D810101
Oct  5 18:13:12.807: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
00436353031
Oct  5 18:13:12.863: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E5
Oct  5 18:13:24.487: %SYS-5-CONFIG_I: Configured from console by eroberson on vt
y0 (172.23.5.49)
Oct  5 18:13:28.427: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
03E4
        Cause i = 0x8A90 - Normal call clearing
Oct  5 18:13:28.475: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x83E
Oct  5 18:13:28.495: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x03E4
Oct  5 18:13:37.643: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x13E7
        Sending Complete
                Standard = CCITT
        Facility i = 0x9FAA06800100820100A1080201000201008400
        Called Party Number i = 0x80, '6277054'
Oct  5 18:13:37.683: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x93
E7
Oct  5 18:13:38.099: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
3E7
Oct  5 18:13:39.443: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x93
E7
Oct  5 18:13:41.655: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x024E
                Standard = CCITT
        Calling Party Number i = 0x2183, '5556452800'
        Called Party Number i = 0x80, '3625'
Oct  5 18:13:41.679: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
24E
Oct  5 18:13:41.679: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x82
4E
        Facility i = 0x9FAA06800100820100A116020101020101800E4A6F686E20446F6E616
C64736F6E
Oct  5 18:13:42.075: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x02
4E
Oct  5 18:13:52.224: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
03E5
Oct  5 18:13:52.264: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x83E
Oct  5 18:13:52.276: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x03E5
Oct  5 18:13:53.628: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
13E7
Oct  5 18:13:53.660: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x93E
7
Oct  5 18:13:53.688: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x13E7
Oct  5 18:13:55.860: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
024E
Oct  5 18:13:55.916: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x824
E
Oct  5 18:13:55.936: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x024E
Oct  5 18:14:21.136: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93E2
Oct  5 18:14:21.140: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13E2
        Call State i = 0x0A
Oct  5 18:14:21.824: ISDN Se0/0/0:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
80BA
Oct  5 18:14:21.824: ISDN Se0/0/0:23 Q931: TX -> STATUS pd = 8  callref = 0x00BA
        Call State i = 0x0A
Oct  5 18:14:22.128: ISDN Se0/0/1:23 Q931: RX <- STATUS_ENQ pd = 8  callref = 0x
93C8
Oct  5 18:14:22.132: ISDN Se0/0/1:23 Q931: TX -> STATUS pd = 8  callref = 0x13C8
        Call State i = 0x0A
Oct  5 18:14:43.908: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
13E6
Oct  5 18:14:43.948: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x93E
6
Oct  5 18:14:43.980: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x13E6
Oct  5 18:15:00.589: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x
03DA
Oct  5 18:15:00.601: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
13E0
Oct  5 18:15:00.621: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x93E
Oct  5 18:15:00.629: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x83D
A
Oct  5 18:15:00.657: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x03DA
Oct  5 18:15:00.661: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x13E0
Oct  5 18:15:07.605: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x03E8
                Standard = CCITT
        Calling Party Number i = 0x2183, '5556396683'
        Called Party Number i = 0x80, '2867'
Oct  5 18:15:07.645: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
3E8
Oct  5 18:15:07.645: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E8
        Facility i = 0x9FAA068001008201008B0100A117020101020114300F0A01010A01028
00734363830303237
Oct  5 18:15:07.657: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x13E8
        Sending Complete
                Standard = CCITT
        Facility i = 0x9FAA068001008201008B0100A12C02010102011530240201010A01018
00101A108A006800432383637A30F800D467265642057657967616E6474
        Called Party Number i = 0x80, '4680027'
        Redirecting Number i = 0x00008F, '2867'
Oct  5 18:15:08.137: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
3E8
Oct  5 18:15:08.273: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x03
E8
        Facility i = 0x9F8B0100A117020101020100800F424541554D4F4E542054494D4F544
8
Oct  5 18:15:08.277: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x13
E8
8
Oct  5 18:15:08.321: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x93
E8
        Facility i = 0x9F8B0100A406020101810101
Oct  5 18:15:08.325: ISDN Se0/0/1:23 Q931: TX -> FACILITY pd = 8  callref = 0x83
E8
Oct  5 18:15:09.589: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x93
E8
Oct  5 18:15:09.593: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x83
E8
Oct  5 18:15:11.453: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x93E
8
Oct  5 18:15:11.457: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x83E
8
        Connected Number i = 0x0081, '4680027'
Oct  5 18:15:11.461: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x13E8
Oct  5 18:15:11.477: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x03E8
Oct  5 18:15:12.857: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x13E9
        Sending Complete
                Standard = CCITT
445524D414E
        Called Party Number i = 0x80, '15555573763'
Oct  5 18:15:12.933: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x93
E9
Oct  5 18:15:13.349: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
3E9
Oct  5 18:15:14.265: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x93
E9
Oct  5 18:15:15.921: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x93E
9
Oct  5 18:15:15.925: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x13E9
Oct  5 18:15:37.673: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x13EA
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98389
                Exclusive, Channel 9
        Facility i = 0x9FAA06800100820100A111020100020100800953756520436C61726B
        Calling Party Number i = 0x2181, '5556452807'
        Called Party Number i = 0x80, '15555799252'
Oct  5 18:15:37.733: ISDN Se0/0/1:23 Q931: RX <- FACILITY pd = 8  callref = 0x93
EA
Oct  5 18:15:37.733: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9
3EA
Oct  5 18:15:40.717: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x
824C
Oct  5 18:15:40.757: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x024
C
Oct  5 18:15:40.785: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x824C
Oct  5 18:15:42.429: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x93
EA
Oct  5 18:15:52.146: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x93E
A
Oct  5 18:15:52.150: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0
x13EA
Silver
The name is coming in in the Facilities packet, on that last call, if you go down the string to the 8009, that says the name is 9 characters long, and if you feed the following 9 characters (string of 18) into a 'hex to ascii' converter, you will see that it is Sue Clark:
http://home2.paulschou.net/tools/xlate/
Mary Beth
Try adding the following under your serial interfaces:
isdn supp-service name  calling
Emilio
Hi Emilio,
I added your suggestion under each serial interface. This is under the config of each serial interface after I added isdn supp-service name calling:
" isdn supp-service name calling profile Network-Extension operation-value-tag local"
It did not change anything as the number still shows up and the name doesnt appear until after the call is picked up.
Is there a setting within Call Manager that could be the issue since the router debug shows that it does see the Caller ID name in the Facility line of the log?
- Eric
Eric,
The ISDN PRIs are configured as MGCP controlled. No changes on the gateway will modify the behavior as all L3 ISDN messages will be sent directly to CUCM which will then process them. If the Calling name is being sent on the Connect or later, then there is nothing that can be done as it's a matter of when it's sent by the telco. If it's sent prior to the connect then the issue may be a limitation of the type of IP phone used. Some of the older phones, 7960/40, can't update the display during the ringing phase due to memory limitations.
One workaround would be to switch the gateway to H.323 and buffer the outgoing call setup to CUCM until the Facility with Name is received. The gateway will then insert the name in the Setup out to the CUCM and it should be displayed immediately.
here is the command guide entry for the feature,
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_h1.html#wp1087669
-Felipe
1151
