Community Member
Caller ID through 2811 on FXO Port
have a Cisco 2811 with a VIC2-4FXO card and one analog line provided by my telco. I am trying to get the caller id sent by the telco to show up on an ip phone that is registered to my Call manager version 7.1. The gateway is configured as H323 and caller-id enabled has been configured on the port. When I debug vpm signal i can see that the caller id is there but unknown name, unknown number always displays on the phone. I have attached a copy of the debug vpm signal output and the configuration on the port. I have also attached an analog phone and it displays the caller id after the first ring. Any help would be much appreciated.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Green
From your trace the incoming call is on voice port 0/2/0:-
000375: *Dec 12 14:03:37.643: [0/2/0] get_fxo_caller_id calling num=2085555555 calling name=My Company calling time=12/12 14:03
From your config voice port 0/2/0 is NOT H323 it is MGCP controlled:-
voice-port 0/2/0
trunk-group PSTN_911
no battery-reversal
input gain -6
echo-cancel coverage 24
timing hookflash-out 50
connection plar 31100
caller-id enable
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
As far as I am aware Caller-ID on FXO using MGCP does not work:-
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml#task6
•Caller ID does not work on FXO ports. This is because caller ID is not supported with FXO ports when configured for MGCP. Configure the gateway in H.323 mode instead.
If the router is in fallback mode IE SRST it should have fallen back to
the the default H323 application
You could try adding :-
voice-port 0/2/0
caller-id alerting ring 1
But this looks like it will only be supported in H323 not MGCP
Alex
Regards, Alex. Please rate useful posts.
Green
Can you post the running config
Alex
Community Member
I attached the config to my original post. Thanks.
Green
voice-port 0/2/0
no battery-reversal
input gain -6
caller-id enable
service mgcpapp
port 0/2/0
voice-port 0/2/0
Alex
Community Member
Thanks!
Hall of Fame Super Red
Hey Guys,
Just as an FYI - CLID support for MGCP-FXO ports was added in CUCM 8.x
Caller ID Support on MGCP FXO Gateways
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/cmadmin.html#wp1115153
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Community Member
Dear Rob,
Dear Rob,
i have same issue, the gateway is configured as MGCP having four port FXO card.
the which you have shared isn't working.
could you please share another link or solution.
Thanks.
7451
