Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Caller id
Can one manipulate the Caller ID for ingress calls from PSTN, either on the GW or Callmanager? I think you can't but wanted to confirm with the gurus!
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Caller id
You can manipulate the caller id ingress with translation rule.
Re: Caller id
You can change it on the gateway if it's h323
Or on cucm either
In the gateway setting using transformation mask
Or
Using a translation pattern as well
Hope this help
If helpful rate
Caller id
Re: Caller id
Or on cucm either
Or
Hope this help
If helpful rate
265
