Community Member
Caller id..
I have configured a CCM server (version 4.2.3 ) and using MGCP gateway. We have say about 100 extensions (IP Phones), the extesion numbers range is from 2100 to 2199. Now when we place a call from any extension (outside calls to PSTN) the caller id is getting displayed is 2100 only (ofcourse with PSTN prefix).... what could be the problem why the caller id is not getting displayed as same as the extension number (along with the PSTN prefix)
Some inputs pls...
P.S. We have DID for these block of 100 numbers (2100 - 2199), and the incoming calls land on the extensions properly..
Hall of Fame Super Silver
Re: Caller id..
Check to make sure that the route patterns have "Use Calling Party's External Phone Number Mask" checked and there is nothing in the "Calling Party Transform Mask" field on the Route Pattern nor Route Group (within route list) nor the GW.
HTH, please rate all posts!
Chris
Community Member
Re: Caller id..
Hi Chris,
Thanks for your reply, I have checked the same its all ok, but still I have the same issue.... What else could be the problem...
Re: Caller id..
Check with your Telco provider to see if they can outpulse DIDs, it appears that they are masking all calls with the Billing Number.
Chris
Community Member
Re: Caller id..
what do your inbound calls look like on your voice gateway?
Community Member
Re: Caller id..
Im using a MGCP gateway, so all the L2 and L3 of ISDN is being controlled on the callmanager itself, so Im unable to see any output for Show isdn active or Show isdn history.... So how else can I find the information you wanted ??
Re: Caller id..
debug isdn q931 will work.
Chris
Community Member
Re: Caller id..
debug output as follows....
for incoming call to extension number 2157.....
ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0022
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838C
Exclusive, Channel 12
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x0083, '24604498'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '157'
Plan:ISDN, Type:Unknown
*Apr 15 16:20:04.915: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x
8022
*Apr 15 16:20:04.915: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8
022
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Apr 15 16:20:10.183: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
x0022
Cause i = 0x8190 - Normal call clearing
*Apr 15 16:20:10.203: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x80
22
*Apr 15 16:20:10.219: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x0022
outgoing call from extension number 2173......
ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x000D
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '24642173'
Called Party Number i = 0x80, '99384599'
*Apr 15 16:22:22.507: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x
800D
*Apr 15 16:22:27.619: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8
00D
Progress Ind i = 0x8488 - In-band info or appropriate now available
Silver
Re: Caller id..
Firstly verify with your Telco that CLID is being honoured outbound.
Secondly, you could be passing too many digits across (you're currenly passing 8). Try masking this on the route list by entering 642xxx on the Calling Party transform mask. This will then force only 6 digits to be presented on the cct.
HTH. Don't forget to rate posts.
Re: Caller id..
It looks like your sending the correct information to the Telco. Like most people have stated, make sure Telco is allowing the digits. Second thing you can try is to make a modification on the mgcp gateway. Under the Gateway Configuration page on the PORT in CM, change the calling party Plan Type to ISDN. Reset the gateway and see if that works. Typically for US, we use National and ISDN.
173
