Caller ID
I currently run VoIP between a number of sites. When I make a VoIP call, the caller ID ends up being the dial-peer prefix. Is there a way to send the callers phone number as well? I am running call manager 5.1 with a standard route pattern pointing to the remote router. Here's the basic config we run
dial-peer voice 265 voip
destination-pattern 265....
session target ipv4:xxx
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
dial-peer voice 267 voip
destination-pattern 267....
codec g711ulaw
dial-peer voice 298 voip
destination-pattern 298....
codec g711ulaw
dial-peer voice 429 voip
destination-pattern 429.....
codec g711ulaw
1 REPLY
Silver
Re: Caller ID
Display (Internal Caller ID) not accepting Unicode Characters
After downloading the Japanese Locale for THX and while trying to save the unicode name in display (Internal Caller ID)
on the line page,it is not able to save the unicode name and throws an error: "Update failed. DeviceNumPlanMap Display has invalid format. Max length is 30. Regular expression used to validate: ^[^]""%<>[&|{}]{0,30}$"
Workaround:
However if the unicode name is put only in the "Alerting name" on the same line page it accepts the same and throws no error. -->
815
