Caller Input + Unity + Forwarding
I am attempting to do the following:
Someone calls (internal) x8000, get's voicemail(Unity) and the option to transfer to someone else. Option 1 is selected, which transfers to x8001. x8001 is set to forward all calls to an external 800 #.
The problem is, when option 1 is selected, it does forward to the x8001 but then goes to a busy signal.
If I dial x8001, it does transfer correctly to the external 800 #
Any ideas are welcome.
1 REPLY
Re: Caller Input + Unity + Forwarding
Does the VoiceMail Ports have a CallingSearchSpace able to join the external number or has the x8001 been set a CallFwd CallingSearchSpace ?
Hope that help
Guy
116
