CallerID dissapears when transferring outside call
In CCME 4.1
When a call comes from fxo
operator answers
callerID appears
then operator transfers to any ip telephone, it shows operator telephone#
instead of outside callers.
Re: CallerID dissapears when transferring outside call
Here is my Config
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone TT-YENiSEHiR
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 500
connection plar opx 3000
shutdown
description 4685000
station-id name 4685000
caller-id enable
ephone-dn 1
number 3000
label 4685000
name Line1
corlist incoming user-longd-gsm-int
ephone 1
device-security-mode none
video
mac-address x.x.16CC
username "xxx" password xxx
type 7931
button 1:1 2:2 3:3 4:4
button 5:5 6:6 7:7 8:8
button 9:9 10m16 11m17 12m18
button 13m20 14m21 15m22 16m27
button 17m28 18m30 19m32 20m37
button 21m39 22m41 23m44 24m24
ephone 2
video
mac-address x.x.525B
type 7906
button 1:23
Hall of Fame Super Gold
This is happening with recent CME and I'm not sure if there is a bug filed, or a configuration workaround. The correct behavior is to show both the caller and the transferrer number so one could tell right that is receiving a call for transfer.
If it is as issue for (I guess it is) please open a case with the TAC. Eventually, we can go back to find the last release were this worked as supposedly has to.
It is exactly the same situation.
I am using latest IOS
12.4(15)T1
I can return back to previous IOS
Which one is rigth?
THANKS
I think this not reletad on IOS
Ephone-1 is the operator phone (making-transfer)
If I assign one externel line to it
as follows, ther is no problem, callerid is displayed on transferred phone display.
ephone 1
video
mac-address 001B.D4C7.16CC
ephone-template 2
username "xxx" password 111
type 7931
button 1:1
If I assign more than one button
callerid is not displayed, instead transferring telephone# is displayed (3000)
Good find, in fact I wasn't able to define a past IOS that worked, I may just have seen the correct working on a phone with only 1 button configured.
Still a bug in my opinion and I will open a case as soon as practicable.
I use IOS 12.4(11)XW2
Nothing changes
Have you had a chance to open a case on this? Is there a case number published?
Thanks much.
116
