CallerID problem from PSTN(FXO)
I have a very strange problem with callerID from my PSTN.
The lines from the PSTN is connected to a vic2-4fxo card with NM-HD-2VE.
I used MGCP for CCM.
PSTN has callerID enabled.
But the line is placed on the fxo, it does not display on the IP phones.
When I connected PSTN line to a analog phone, I get callerID displayed on the the analog phone.
1 ACCEPTED SOLUTION
Re: CallerID problem from PSTN(FXO)
caller ID on FXO is not supported using MGCP, if you want called ID you need to switch to H323
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
188
