tka
CallForward availability when Publisher is down !!!
Hi all,
When the publisher is down, is CallForwarding available only using the softkey button on the phone or it should be also possible to configure it from the web interface of the subscriber ?
Thanks in advance
Re: CallForward availability when Publisher is down !!!
It depends what version of call manager you are running. In earlier versions if call manager eg 4.x if the publisher is down you will not be able to make any changes eg call forwarding however in the newer versions 6.x this is possible. If you using SRST you can configure this feature there.
tka
first thanks for your reply,
However, is it possible through the administration web interface or just using the softkey button ? ( CUCM 6.1)
regards,
121
