Callforward
Can anyone advise on how can I configure to show call forwarded's Caller ID from origin instead of the main number?
Callforward
On the line settings forwarded call infmn display
check caller number and redirected number
VIP Super Bronze
Callforward
is this for an IP phone to IP Phone call? or A PSTN to IP Phone call?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Callforward
It is PSTN to IP phone.
Say that the Internal IP phone is forwarded to cell phone, thus when someone from outside to call in and divert to user's cell phone. Unfortunately, the main line number will be shown on ring cell phone instead of origin desk number. Any ideas?
VIP Super Bronze
Callforward
Wayne,
This is expected because your gateway is using the calling number isntead of the redirecting number as the ANI. Your telco is then replacing the ANI because that number is not part of your DDI range..To resolve this you can change the ff settings on your gateway..
Go to your gateway...
then scroll to call routing information : outbound calls
Then under calling party selection:select "First Redirect Number (External)"
Ensure you have External number mask configured for your ip phones...If you dont then you need to use f"irst redirect number" only...
You will then need to configure a xlation rule on your gateway to modify your internal extension to a valid DDI
Callforward
I assume gateway is the Cisco Call manager?
Can you show the configuration? Manay thanks
VIP Super Bronze
Callforward
No, gateway is not CUCM. What is your setup? can you describe your setup...eg
CUCM-----h323--gateway---pstn
or
CUCM--sip--CUBE---sip----pstn
Callforward
My setup is simple.
cME---PSTN
VIP Super Bronze
Callforward
Wayne please add this under telephony-service
telephony-service
calling-number local
Test again..if it doesnt work...
Pls do a test call and send
debug voip ccapi inout and debug isdn q931
186
