CallForwardAll - Results in "Your call cannot be completed…"
We have a Cisco UC manager 6.1.2 here. For all 7941 phones, when the users select "CallForwardAll" button from the phone, it gives message of "Your call cannot be completed..." and then drops the call. Only the phone works is 7961. It sounds like the configuration issue on the phone profile but I don't know where to look for it. Any suggestions on where to start?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi there,
The first place to look is on the DN config page for one of the
7941 phones. You will likely see that there is no Call Forward All
CSS (calling search space) set up You will also want to check
what is different between the working and non-working devices. It may be
the setting (on the same page as before) called;
Calling Search Space Activation Policy
Let us know.
Cheers!
Rob
Your CFA CSS is not allowing you to dial what you need, review it.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi there,
Let us know.
Cheers!
Rob
Yes. That was the issue. Those extensions with issue didn't have proper CSS assigned.
322
