Calling an IP Phone from router CLI
Which command can be used to call an IP Phone from a router Command Line Interface.
VIP Super Bronze
Re: Calling an IP Phone from router CLI
if you are using h.323 gateway, the command is..
csim start X.X.X.X where x.x.x.x =DN you want to call
NB: this is used from the privilege mode
You cant use this with MGCP..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi thatnks for your response. I use a 1760 h.323 gateway. In the priveledge mode, the command "csim start" is not there and when I do a question mark at the priviledge mode, I dont see the option "csim start".
VIP Super Bronze
Peter,
its a hidden command.
just type in csim start < directory number u want to call> and hit enter, then see what happens
I tried it but got the output below:
Router#csim start 1003
csim: called number = 1003, loop count = 1 ping count = 0
csim err:csim_do_test Error peer not found
Router#
VIP Super Bronze
what that means is that you do not have a voip dial-peer that is responsible for routing the called number..
you need to have a voip dial-peer that will route the call...
Hall of Fame Super Red
Hi Peter,
Hope all is well :)It must be entered this way;
csim start
Hope this helps!
Rob
I want to add that this should NOT be used in any sort of formal testing. csim start does not make a proper RTP stream and therefore negotiations of certain protocols will throw errors that aren't real, seeming like links and connections aren't working, when they actually are! (i.e. try csim start over a QSIG T1 and watch it fails with random error's! )
Cheers,
Chad
1160
