Silver
Calling from Mexico to US
All,
I have a CME site in mexico that has a generic dial-peer set up to route 9T calls out the telco line.
What is the best way to set this up?
How do you place a call outbound from this site, non-VoIP call?
I do not know how to dial the US from a Mexico phone.
voice translation-rule 2500
rule 1 /2500/ /1001/
rule 2 /2501/ /1001/
rule 3 /2502/ /1001/
rule 4 /2503/ /1001/
rule 5 /2504/ /1001/
rule 6 /2505/ /1001/
rule 7 /2506/ /1001/
rule 8 /2507/ /1001/
rule 9 /2508/ /1001/
rule 10 /2509/ /1001/
rule 12 /2510/ /1001/
voice translation-profile MAIN
translate called 2500
controller E1 0/0/1
framing NO-CRC4
ds0-group 1 timeslots 1-10 type r2-digital r2-compelled ani
cas-custom 1
country telmex use-defaults
category 2
answer-signal group-b 1
voice-port 0/0/1:1
dial-peer voice 2 pots
destination-pattern 9T
port 0/0/1:1
forward-digits all
Rick
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Calling from Mexico to US
Your generic dial-peer forwards all digits inculding the 9, the quickest solution would be to remove the "forward-digits all" command, but I would recommand making more explicit dial-peers as this one will always introduce inter-digit timouts. Create one for Local, LD, International and emergency dialing.
Chris
00 - international direct dialing (00 + country code + nat'l number) including USA and Canada.
01 - domestic direct dialing (01 + area code + number)
02 - domestic operator dialing (02 + area code + number)
09 - international operator dialing (09 + country code + number) including USA and Canada.
Chris
Chris
Silver
I plan on doing that, but wanted something to test with first.
How do I strip the 9 so just the actual number outpulses?
Do I just remove the foward digits command?
Everything else look ok?
Silver
Silver
Yes, pots dial-peers automatically strip explicitely matched digits, so in your case since 9 is explicitely matched it will not be forwarded.
HTH,
Chris
Silver
awesome this is what I thought but still new to all of this. more familiar with CUCM 6.1
Now about dialing out in Mexico, how do you make a stateside call?
is it the same as done here in the US, 1---####
Community Member
I believe it is 001-NPA-NXX-xxxx
Chris
Silver
Thanks Chris.
I found a lovely little cisco feature that when you do no forward-digits all
it likes to make that statement forward-digits 0
I had to remove the whole dial-peer and reapply the config without the forward statements.
Thanks for everything!
Also, CDW, where you based out of? we are using them a lot for our IPCC and now getting Voice Advantage for a lot of issues I cannot either get to or resolve myself, we have been getting support from Southfield, MI
I am out of Chicago office, hopefully we are treating you well :-)
Chris
Silver
422
