Calling Name Presentation on Cisco IP-phone
fdetoma
there is a way to remove (only external) Calling Name Presentation from phone display?
So, we need to show, on called phone display, only calling number ID and nothing else from external....
I've tried to modify Calling Name Presentation from default to restricted and now we receive "privat" followed by calling number.
We want remove from display also this "privat" text....
Is possible do this setting?
Thansk!
fdetoma
do you have some news about?
Any idea...?
Thanks!
is that for external outgoing call? if so, can you ask your provider to block the name from their side?
//Suresh Please rate all the useful posts.
no,
we need to completely remove this "text" only for external incoming call.
When external user call internal DN, we need to see only calling number on called phone display...
If possible this?
Thanks!
May be you can try the solution suggested in this thread.
https://supportforums.cisco.com/discussion/11042201/cube-modify-or-delete-sip-display-name-calling-name
voice class sip-profiles 1
request INVITE sip-header Remote-Party-ID remove
request INVITE sip-header From modify "From: (.*<)(.*>)" "From: <\2"
I am sure there are multiple ways of doing it...this shd work though....
If u want to remove that name from All msgs/responses...simply use ANY keyword
(instead of INVITE)
//Suresh
