Community Member
Calling number not displayed from PSTN
I have CCME that is connected via 2E1 to PSTN .when i make an incoming call from PSTN, the calling number is prompted in the "debug isdn q931", but unfortunately it's not displayed at the IP phone, and the Unknown message is displayed.
Please help me to resolve the problem.
thanks.
Re: Calling number not displayed from PSTN
In your CM check for the DN configuration to allow the number pass through. Also check your IP phone settings.
Community Member
thanks for reply
but me i don't have any CM, i have just CCME.
The fact that the calling party number is in the incoming setup message suggests that CLIP is being passed by the Telco.
Initially check any translations that you have configured or applied to your inbound POTS DID dial-peer that change calling party, especially if you prefix the trunk access code and 0 for instance.
Verify the voice translation-rule with 'test voice translation-rule x 01234987654' for example.
Can you post the configuration and the output of the 'debug isdn q931'.
Allan.
Community Member
the debug is here :
Router#
Dec 11 08:59:26.975: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref = 0x001F
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98398
Exclusive, Channel 24
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x0083, '022223915'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '20'
Plan:ISDN, Type:Unknown
Dec 11 08:59:26.987: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x801F
Dec 11 08:59:27.035: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8 callref = 0x801F
Dec 11 08:59:27.091: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8 callref = 0x801F
Dec 11 08:59:27.147: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x001F
Dec 11 08:59:27.147: %ISDN-6-CONNECT: Interface Serial0/0/1:23 is now connected to 022223915 N/A
Dec 11 08:59:30.111: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1:23, changed state to up
Dec 11 08:59:33.023: ISDN Se0/0/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x001F
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 11 08:59:33.023: %ISDN-6-CONNECT: Interface Serial0/0/1:23 is now connected to 022223915 N/A
Dec 11 08:59:33.023: %ISDN-6-DISCONNECT: Interface Serial0/0/1:23 disconnected from 022223915 , call lasted 5 seconds
Dec 11 08:59:33.023: ISDN Se0/0/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x20
Dec 11 08:59:33.039: ISDN Se0/0/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x801F
Dec 11 08:59:33.063: ISDN Se0/0/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x001F
135
