Community Member
Calling number not displaying in MGCP gateway..
The calling number is not getting displayed for the outgoing calls which go through the MGCP gateway..
I have taken a isdn q931 debug when we try to make outgoing call from our ip phone, the output is as below...
*Jun 25 19:42:25: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Display i = 'Sohel Ahmed'
Called Party Number i = 0x80, '99384599'
Plan:Unknown, Type:Unknown
*Jun 25 19:42:25: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8 callref = 0x8001
Cause i = 0x829F - Normal, unspecified
Call State i = 0x01
*Jun 25 19:42:25: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8001
*Jun 25 19:42:29: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8001
Progress Ind i = 0x8488 - In-band info or appropriate now available
you can see that the debug shows the called party number which I'm calling from my ip phone, but it is not at all displaying the calling party number which should be my extension number...
Due to this when the other end party recevies our call it displays our pilot number instead of the individual extension number...
can someone give your inputs on this...
Silver
Re: Calling number not displaying in MGCP gateway..
Gateway Configuration-> select your ISDN interface-> Outbound Calls-> "Caller ID DN field" configure the Caller ID.
You can also do this on the Route List configuration page. The Gateway config overwrite the RL config.
Community Member
It has been already configured.. but same issue...
where are you setting the calling number in CUCM??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
yes, I'm setting in the CUCM, in the gateway configuration only...
Silver
On the Gateway Configuration-> Outbound Calls-> what did you set for "Calling Party Presentation" if it is restricted you need to change it to "Default"
Community Member
Yes, it is set to default..
Infact following are the configurations set in the Gateway Configuration-->Outbound Calls...
Calling Line ID Presentation --> Default
Calling Party Selection --> Originator
Called party IE number type unknown --> Cisco CallManager
Calling party IE number type unknown --> Cisco CallManager
Called Numbering Plan --> Cisco CallManager
Calling Numbering Plan --> Cisco CallManager
Number of digits to strip --> 0
Called ID DN --> 254XXXXX
SMDI Base port --> 0
Silver
So if you are calling from say 55000 from you IP phone, the called party should get 25455000.
Can you now tell us if that is the case? or what number get displayed on the Called party phone?
Community Member
The called party gets the display on his/her phone/mobile our pilot number (ie 25446600)..
but ideally the called party should get in thier display the extension number of the ip phone from which the call was made.. for example it should be displayed 25446605 if the call was made from the extension 6605..
Community Member
Have you checked the E1/T1 card on the gateway to see if the CLI has been set to restrited?
Community Member
how can we check in the gateway?? did u mean the gateway configuration in the CUCM ?? if so I have done it and it is set to default..
post the sh run of the gateway please ;)
Community Member
Hi, Sorry I had not read the other post and I can see that you had enabled it.
Have you tried to see the call flow on Dialed Number Analysiser on the CallManager, this will confirm you configuration. If this is ok, enable trace and view the call using VLT (downloadable from Cisco).
You may also want to check with your provider, to see if your PRI is enabled to send out the DID's on outbound caller id, or if its just set to send out the billing telephone number.
Community Member
Try changing your GW config for the PRI outbound calling: Calling party IE number type unknown to national and the Calling Numbering Plan to national standard. This should fix your problem
486
