Calling party ID issue...
I'm having an issue with a local service provider and I was hoping someone could help out. The customer I'm working with wants individual extensions to be passed as the calling number for external calls. The extensions are masked with the area and exchange codes at the route level. The gateway is an MGCP gateway.
Now every time an outside local number is called it receives the main listed number as the Calling party number.
I can see, using debug isdn q931, that we are sending out the extension info and not the main listed number. However, the service provider insists that we are not sending them anything or that we are sending the main listed number.
Am I right in my assertion that the Called Part Number field of the q931 debug is the information we are sending? I personally think the service provider is full of it. But I want to make sure.
Thanks!
Justin
Hall of Fame Super Gold
Re: Calling party ID issue...
Hi Justin,
please send the q931 trace here. If we agree, as it's likely, that is correct, you are ready to fax it to telco (if they don't use email yet :)
Just mask a digit or two if you are concerned about making the numbers visible.
Here's a copy of the debug-
2851#
Jun 12 15:47:27.199: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0008
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Display i = 'Garner Sales'
Calling Party Number i = 0x0081, 'XXX7557070'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA0, '6124214'
Plan:Unknown, Type:National
Jun 12 15:47:27.595: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8008
Jun 12 15:47:29.343: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8008
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun 12 15:47:30.795: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x8008
Jun 12 15:47:30.831: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0008
Jun 12 15:47:36.099: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0008
Cause i = 0x8090 - Normal call clearing
Jun 12 15:47:36.343: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8008
Jun 12 15:47:36.423: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0008
I masked the area code but it is the correct one.
Justin
Hi Justin,
two things that possibly the telco wants to have different, perhaps they want the calling number to be your DID only, like 3 or 4 digits, let's say the same number of digits you receive for incoming calls. Then also check what plan/type they set for for incoming calls, so it can be set to be the same.
158
