Calling Party Name missing on VG224 FXS port
I am troubleshooting an issue with the calling party name missing from analog phones caller-id causing the phone to display unknown name or out of area for the calling party information.
The setup is as follows: PSTN PRI---3825---(MGCP)---CUCM---(SCCP)---VG224---FXS port. CUCM version 6.1.3
Telco is providing the calling party number in the SETUP message which is being forwarded to the VG224 analog port fine. However, the issue is the telco is not providing the calling party name until the FACILITY message. Once FACILITY arrives, CUCM already routed the call to the analog phone with missing calling party name information which causes the unknown name information to be displayed by the VG224 connected phone. TAC is suggesting converting the MGCP gateway to H.323 gateway but this will add additional management and monitoring issues.
Telco says that they cannot add the calling party name to the SETUP message.
Has anyone else ran into this problem and if so, is there any way to fix this issue without doing a conversion on the gateway?
sh run of the PRI and debug output below:
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
end
003970: *Mar 5 22:59:20.904: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8186
Progress Ind i = 0x8288 - In-band info or appropriate now available
003971: *Mar 5 22:59:21.052: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0x8186
003972: *Mar 5 22:59:21.060: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0186
003973: *Mar 5 22:59:30.312: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x1879
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A10F02013E06072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02013E06072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 62
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2180, '408XXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '623XXXXXXX'
003974: *Mar 5 22:59:30.332: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x9879
003975: *Mar 5 22:59:30.332: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x9879
Progress Ind i = 0x8088 - In-band info or appropriate now available
003976: *Mar 5 22:59:30.856: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x1879
Facility i = 0x9F8B0100A11702013F020100800F434953434F2053595354454D532020
0xA11702013F020100800F434953434F2053595354454D532020
Invoke Id = 63
Operation = CallingName
Name Presentation Allowed Extended
Name = CISCO SYSTEMS
003977: *Mar 5 22:59:33.168: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0184
Cause i = 0x8090 - Normal call clearing
003978: *Mar 5 22:59:33.204: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8184
003979: *Mar 5 22:59:33.216: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0184
Called party numbers do come across OK, I manually added the XXXXXXX to the numbers.
Green
Re: Calling Party Name missing on VG224 FXS port
Unfortunatly No, we discuss this with De time ago and problem is Call Info message once is recieved by the VG224 cannot be updated with new Call info message after ISDN Q931 Facility arrives.
The feature you're needing to use is documented here:
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/release/notes/rn2800xw.html#wp363697
I do not believe that MGCP has this capability. This is probably why TAC is suggesting a change to H323.
hth,
nick
It definitely does...next questions.
1) Is it possible for the Telco to send the calling party name in the SETUP message or is that something that the protocol doesn't support?
2) Do you think that having an MGCP gateway send the calling party name from the FACILITY message would be something that could be supported in a future release?
It is normally sent in the SETUP message. To do otherwise is abnormal, and which is why we have a new feature to support it in the facility message afterwards.
I don't currently know of any plans to implement that in MGCP. If you would like to have this changed, you can talk to your account team to have a feature request filed.
hth,
nick
604
