Calling :Party Number PRI
I am having this weird issue with Calling Party number displaying my BTN on outbound calls. My route parttern is set to "Use External calling party number" My phone is set to the correct external calling party info. This is a new site and I never put the BTN number into the config. But when I do a dubug isdn q931 "calling party number" is my BTN to the telco???? Could the telco be doing this because I have looked over my Router Pattern/RG/RL/Gateway and I do not have this number listed anywhere. Ideas?
Hall of Fame Super Gold
Re: Calling :Party Number PRI
Is that H.323 ? If so perhaps the number is configured in the router,
No MGCP
Is not that you are testing with some forwarding, and the number is carried over someway? Reasonably if you never put that number in config, there is no way CM knows it.
219
