Calling Party Transformation Mask apply to fqcn instead of the cn
I have the following call flow:
IP Phone A --SCCP --> CUCM ---> SIP ---> CUBE --> SIP Provider
I need to prefix a code on the External Phone Number Mas before the call is send to the CUBE. I tried to use the Calling Party Transformation Pattern but it use the cn to match instead of the fqcn.
Is there a way to use the fqcn ?
Weird part is that in DNA Analysis, it shows that applies the change (in the Transformed Calling Party field)
CUCM 9.1.2
Thanks in advance
1 ACCEPTED SOLUTION
Silver
You can use a translation pattern to turn on External Number mask first before hitting your route patterns.  That way you can then do Calling Number Transformation matching the fqcn.
HI,
There is a BIG difference between Calling party transformation, and Translation patters.
Why do you rather than do that, make the change on the RL or RP level. (RP/RL used for cube).
You can also put a TP in the flow, before matches the RP.
From there you can chose external phoen number mask, or event mask it to a fix number so the CUBE can handle the call just fine.
Let me know if you will like me to elavorate more.
Please kudos if it help.
Please Kudos/rate if this help!
VIP Super Bronze
I agree with Jose, doing it at the RL level is a much better approach. I doubt if you can even do this with external number mask. This is a mask not the calling number, hence your calling party transofrmation is not likely to match
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Silver
Thanks All for the answers.
The problem was that the Translation Pattern didn't have the External Number Mask checked.
Basically the call hits a Translation  Pattern (that globalizes the called number), then it hits the Route  Pattern (which has the External Number Mask checked) from there it goes  to the CUBE RP/RL
So it looks like in this call flow:
TP ---> RP --> RL --> RG --> GW
Even if it has the External Phone checked at the RP  level, it takes precedence whatever manipulation is done at the TP and  is the value used as the cn=
188
