Calling phone sees wrong setup information
Following is the setup-
18072553---seimens hipath4k (istanbul)---2821-RIST1WAN1---FR---2821-B---nortel cs1000m (london)---10216334
When Istanbul call London the calling party sees "London" displayed on his phone but not the ANI+DNIS. However called party in London sees both. The other way it works fine.
I checked the incoming setup message on 2821-A and the ANI+DNIS information was present.
Oct 15 10:38:15.150 MESZ: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x000D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18382
Preferred, Channel 2
Facility i = 0x91AA068001008201008B0100A11D02022D9606042B0C0900A111040C4D45484D455420414B444153020101
Calling Party Number i = 0x0083, '2553'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '10216'
High Layer Compat i = 0x9181
Locking Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x80
Oct 15 10:38:15.158 MESZ: ISDN BR0/1/0 Q931: TX -> SETUP_ACK pd = 8 callref = 0x800D
Channel ID i = 0xA98382
Exclusive, Channel 2
Oct 15 10:38:15.894 MESZ: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8 callref = 0x000D
Called Party Number i = 0x80, '3'
Oct 15 10:38:17.414 MESZ: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8 callref = 0x000D
Oct 15 10:38:18.154 MESZ: ISDN BR0/1/0 Q931: RX <- INFORMATION pd = 8 callref = 0x000D
Called Party Number i = 0x80, '4'
Oct 15 10:38:24.854 MESZ: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x800D
Facility i = 0x91AA068001008201008B0100A11302020100020102800A4575616E2057616C7368
Progress Ind i = 0xA194 - Reserved value
Connected Number i = 0x8095, '2', 0x0180, '6334' >>>>>> not sure why this is like this, never observed something like this.
I'm quite baffled as to why the calling party sees "London" instead of ANI+DNIS.
Even if I assume that the CNAME from FIE is being displayed that doesnt match either. I checked the FIE with a decoder and it says "MEHMET AKDAS". If the 2821's are swapped with Vangaurd routers everything works just fine. So I'm not sure if this is with some QSIG incompatibility between Cisco and PBX.
There isn't any compatibility matrix/sample test for Nortel CS1000M and Cisco using QSIG+H.323.
Any pointers would be great, thanks in advance.
142
