calling sip line from outside
dears,
any one can help, i have these config in my translation rules
incoming calls are working when i dial 2837555 from outside , but some are saying that when they call from certain numbers the number 2837555 it will be busy.
voice translation-rule 1
rule 1 /2837599/ /599/
rule 2 /2837595/ /595/
rule 3 /2837597/ /597/
rule 4 /2837598/ /598/
rule 5 /2837400/ /100/
rule 6 /2837596/ /596/
rule 7 /.*2837555/ /123/
rule 8 /^1\(.......$\)/ /9\1/
rule 9 /\(^5........$\)/ /90\1/
rule 10 /^9\(.*\)/ /\1/
rule 11 /^.*\(123\)/ /\1/
voice translation-rule 191
rule 1 /^599/ /2837599/
rule 2 /^596/ /2837596/
rule 3 /^595/ /2837595/
rule 4 /^597/ /2837597/
rule 5 /^598/ /2837598/
rule 6 /^3....\*\(.\)/ /\1/
rule 7 /^9\(.*\)/ /\1/
rule 8 /.../ /2837555/
voice translation-profile SIP-IN
translate calling 1
translate called 1
voice translation-profile TP_OUT_SIP
translate calling 191
translate called 191
Everyone's tags (4)
VIP Super Bronze
can you send a debug ccsip messages and debug voip ccapi inout
Please rate useful posts
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: calling sip line from outside
hi,
tthanks for your support, please find logs as requested , called from 2835625 to 2837555 but call not going to AA
VIP Super Bronze
Hi, here is an analysis of your trace..
+++Your sip provider sends an invite without SDP+++So you are doing delay offer
Received:
INVITE sip:2837555@10.196.106.122:5060;
user=phone SIP/2.0 Via: SIP/2.0/UDP 10.200.7.157:5060;
branch=z9hG4bKj8nb8liui7vhlohlv7bnvkhkc
Call-ID: SBCk2aedpp2u2otuptbbfes2okad7aehaec@SoftX3000
To: <2837555>
+++After a couple of trying and invite to CUE, you send a 200 ok to provider with SDP++++.
Sent:
SIP/2.0 200 OK Via: SIP/2.0/UDP 10.200.7.157:5060;
To: <2837555>;tag=2E4C4AD0-263D Date: Sat, 02 Jun 2012 08:49:51 GMT
CSeq: 1 INVITE Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER Allow-Events:
telephone-event Remote-Party-ID: <123>;party=called;screen=no;privacy=off
Contact: <2837555> Supported: replaces Call-Info: <10.196.106.122:5060>;method="NOTIFY;Event=telephone-event;Duration=2000" Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x Supported: timer Content-Type: application/sdp
Content-Disposition: session;handling=required Content-Length: 251
v=0
o=CiscoSystemsSIP-GW-UserAgent 336 981
IN IP4 10.196.106.122
s=SIP Call
c=IN IP4 10.196.106.122
t=0 0
m=audio 17614 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15 a=ptime:20
++++++++Now your provider sends an ACK without sdp+++++++++++ (for it to work they need to send an ACK with SDP)
Received:
ACK sip:2837555@10.196.106.122:5060 SIP/2.0 Via: SIP/2.0/UDP 10.200.7.157:5060;
branch=z9hG4bKeljk7bluenjvkjibkvniyujjx
To: <2837555>;tag=2E4C4AD0-263D CSeq: 1
ACK Max-Forwards: 70 Content-Length: 0
+++Then your provider sends a bye+++++++++++
Received:
BYE sip:2837555@10.196.106.122:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKxnknekbionkvbvoxbnkliiexc
CSeq: 2 BYE Max-Forwards: 70
Reason: Q.850;cause=41;text="temporary failure"
Content-Length: 0
+++The ccapi cause code helps us more++++
001281: Jun  2 08:49:51.877: //127822/C058B05B8462/CCAPI/cc_api_call_disconnected:
   Cause Value=96, Interface=0x8738CB14, Call Id=127822
Cause 96 means that a mandatory information element is missing..Now the question is what is the mandatory information your provider is expecting in the 200 answer that you didnt provide..and I think its this sip session attribute
a=sendrecv or a=sendonly
Now according to RFC 3264  An Offer/Answer Model Session Description Protocol , it stipulates that
If the offerer wishes to both send and   receive media with its peer, it MAY include an "a=sendrecv"
   attribute, or it MAY omit it, since sendrecv is the default
However I think Huwaei your sip provider still want to see a session attribute in your offer. Hence the reason for disconnecting the call.
My suggestion is to use early offer from the provider. That way they can send you their attributes and ccme can just ack that.
It is my experience with this provider that they always send a session atrribute even if its  (a=sendrecv) which is the default.
hi,
i am not sur that i get you
can you specify what to do to solve this issue.
hi
you mean i have to configure early-offer as below
Configuring Delayed-Offer to Early-Offer for SIP Audio Calls at the Global Level
To configure Delayed-Offer to Early-Offer for SIP Audio Calls at the global level, perform the steps in this section.
SUMMARY STEPS
1. enable
2. configure terminal
3. voice service voip
4. allow-connections sip
5. early-offer forced
6. exit
VIP Super Bronze
Yes try that and test again...send the debugs again after you have configured this.
hi, i tried to add the commands but it doesnt support
Try to create voice class sip-profile. Add the missing header in your 200 OK response and test.
voice class sip-profile 1
Response 200 sdp-header attribute add "sendrecv"
Then assign this profile to your matched dialpeer.
Baqari
Hi Baqari,
i tried adding the profile, but the call is not going to autoattend, but it keeps on ringing, if i remove the command from the dial peer, the specific number is not working but other nos are going to the auto attend.
Please share the debig after adding the command
                 hi
debug as requested
VIP Super Bronze
Can you please add this..
Response 200 sdp-header attribute add "a=sendrecv"
NB: That the previuos config didnt have a=sendrecv, so you provider was ignoring your 200 ok.
Ensure to apply the profile to the dial-peer going to your sip provider as you did before. Please test again and send debug ccsip messages
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Hi Edwin,
In fact its typo mistake I forgot to put "a=" while posting the SIP-Profile. Apologize for this. I can see the SDP header is added as "sendrecv" in your debugs without "a=".
I am pasting the new SIP-Profile with the correction.
response 200 sdp-header attribute add "a=sendrecv".
Try now and paste the result.
Thanks to aokanlawon for picking it up
  hi,
still the same, it keeps on ringing without going to the AA
VIP Super Bronze
Did you remove the previous wrong sip profile config because I can still see the wrong attribute sent to your provider..The one underlined is still there and this format is wrong.
s=SIP Call
t=0 0
sendrecv
a=sendrecv
Please ensure you do not have:
response 200 sdp-header attribute add "sendrecv"
That the only one you have is :
                   hi,
thanks for the support sorry to say it didnt work, all other calls goes to aa, but the making call as early specified no. keeps on ringing
VIP Super Bronze
Edwin,
Can you confirm that this number is your AA number 2837555
Also remove the voice profile configuration because your provider doesnt like it and is not responding to it.
Can you also confirm you have other AA numbers that are working..Is this just the only number that is not workinmg?
If you have other AA number that is working can you send  a trace for a working one?
hi ,
2837555 is the only number
aa extn is 123
all other nos are configured for directline
VIP Super Bronze
Edwin,
I have seen a similar problem with this particular sip provider for calls to AA on unity express. To confirm if you are having the same problem can you tell me what codec you use for direct calls? is it G711alaw.. You can send a trace for calls to direct line here so I can quickly have a look.
Can you also configure a test call such that your direct line uses G711ulaw to the provider.  Let me knoe if you need help with the config.
The problem is similar to what a user on this forum has with this same provider for calls going to CUE using g711ulaw.
So if you can do this tests and confirm then we can determine if your issue is similar
hi,
this is provided by the SIP line provider
Customer IP address= 10.196.106.122/30
STC IP Address =   10.196.106.121/30
Protocol= SIP
SIP Port = 5060
Transport Protocol=UDP
Voice Codec= G711 A-Law
DTMF = IN-Band DTMF with RFC2833
SIP Server IP address = 10.200.7.157
VIP Super Bronze
So there is your problem..Your provider cant do G711ulaw. This is the only codec supported by Unity express. Have you confirmed that your phones are only doing G711alaw. This is important.
If this is the case you either speak to your provider or find another provider because calls to voicemail will not work and AA will not work.
hi,
but i dont have problem with any other nos calling me.
i am not getting the calls from the number  to 2835625
when i dial from 2835625 to my number 2837555, it gives a busy tone.
VIP Super Bronze
Edwin,
Can you please aswer my questions. What codecs do your direct calls use? G711alaw or G711ulaw? Please answer.
I dont know what numbers you are talking about, bear in mind I dont know what your system config is like.  You said 2837555 is AA (Auot attendant) How is it your number again...I am confused..
hi,
can you please provide the config for test call such that your direct line uses G711ulaw to the provider.
1425
