Community Member
Calliung CCM 4.2 and CME locations
I trying to determine the best method to route calls between a CCM 4.2 and CUE location. I have a Intercluster Trunk to route calls to the CME site via an MPLS network. In the event of a failure I want to end the calls over the PSTN. What would be the easiest method, AAR, multiple, Route Patterns, other? Your input is appreciated.
Re: Calliung CCM 4.2 and CME locations
You need to configure a route list which contains the H323 GW and then the PSTN GW, adding the necessary prefixes for PSTN
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
This I have done. How do set priority between Route-list containing the ICT and the PSTN.
Let's get something straight, an ICT is to connect 2 CUCM clusters. To connect a CUCM to a CME you need to configure the CME as an H323 GW. So there can't be an ICT in this config.
H323 1st element
PSTN 2nd element
java
java
Community Member
You are correct I have a H.323 gateway configured to access my CME. I guess my problem is in building the Route Group, my H.323 GW is not listed as a possible element which I can choose. I only see my PSTN GWs
If the H323 is already in another RG or selected under a route pattern, it cannot be used again. You need to take it out from any other RG or RP to use it.
java
java
123
