Community Member
callmanager 4.0 and 6.0
Hi All,
is it possible to use 6.0 and 4.0 in the same environment? for example 6.0 would be publisher and 4.0 would be subscriber.
thanks
Alex
Re: callmanager 4.0 and 6.0
Hi friend,
A cluster may contain a mix of server platforms, but all servers in the cluster must run the same Unified CM software release.
Regards.
as mentioned it's not possible to mix versions (not to say you're trying to mix linux with windows!!), but you can have a 6.0 and a 4.x server standalone and use an ICT if you need both versions in same company
in any case even if you try it would tell you that it simply cannot be
java
if this helps, please rate
java
www.cisco.com/go/pdi
111
