CallManager 4.1(3) CDR DB Schema
Our CU has callmanager 4.1(3)es11 installed with centralised call processing.We have also enabled CDR.
We would like to know whether there is any handbook for CDR database schema? If yes, then kindly provide URL for the same.
Tanmay D.
91-9892555229
Gold
Re: CallManager 4.1(3) CDR DB Schema
You can take a look to these two links:
Cisco CallManager 4.1(3) Call Detail Record Definition:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_usage_guide09186a00806556fb.html
CDR Search Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f52ba.html
Hope this helps,
Juan Luis
You can find the "Cisco Unified CallManager Developer Documents" at http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/index.htm
then you should select the version of CCM that you have and search for the "Cisco CallManager XXX CDR Definition"
410
