CallManager 4.1.3 to 7 (Intercluster)
Hi all
Can anyone tell me if you can create intercluster trunk between CM 4.1.3 and 7.0
Thanks in advance
1 ACCEPTED SOLUTION
Re: CallManager 4.1.3 to 7 (Intercluster)
Yes, configure an ICT non-GK controlled between them and you're good to go
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
174
