11-27-2009 05:05 AM - edited 03-15-2019 08:38 PM
Is it possible to set up an answering service on CM 4.1(3), that are menu based?
I.E Customer calls and get an answering machine that states: "Dial one for sales, Dial 2 for technical support.." etc
If not, what is needed to get this feature?
Best regards
Ole Vik
Solved! Go to Solution.
11-27-2009 06:06 AM
Most commonly this is done by simply using Unity, CUC or CUE
CUCM by itself cannot do anything of that, CUCM is a call agent, not an IVR
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-27-2009 06:06 AM
java
