Community Member
CallManager 4.1 show command... interpretation
I'm looking for a tool able to interpret the show ... command (dos command)
This should be very helpfull when trying to understand some customer configurations without connecting to him.
The best should be to have a pdf document with all informations sorted by categories.
Fred
Bronze
Re: CallManager 4.1 show command... interpretation
'show voice call summary' command:
3660GW#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
1/0:23.1 - - -
1/0:23.2 - - -
1/0:23.3 - - -
1/0:23.4 - - -
Especially, you can get value for CODEC, VTSP_STATE, and VPM_STATE.
This URl hsould help you:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fvvfax_r/vrf_r.htm#1188694
Hall of Fame Super Gold
Hi, all the show commands are documented in the reference manual. Is there something in particular that you would like to be clarified ?
Community Member
Hello....:))
Seems there is a VERY BIG Misunderstanding....
I'm Not Talking about an IOS show commend ...
BUT as stated in the SUBJECT about the CallManger show command which send the callmanager database content.....
Hope that this will clarify this thread
and thanks to vote 1 for the question
Fred
Your question (to which I don't know the answer) has not been low-rated. Rather, an answer was.
110
