Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CallManager 4.2 - logging
I have a Unified Call Manager 4.2 and a Jtapi user created to 'connect' CCM environment to a CallCenter software. I am heaving problems with some routing points. When I make a call to an RP it takes around 10 seconds for the RP to respond and some RP's don't even respond - they give busy signal. Everything worked fine last week and since the I didn't made any changes.
I wanted to know how to enable logging on CCM so when I will call a RP I will be able to see all the cti events and signaling that takes place?
Thanks!
1 REPLY
Silver
Re: CallManager 4.2 - logging
Here you go:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
There are also a CTI traces C:\program files\cisco\traces\sdi\cti
210
